Have you run ur fingers around the pipes to see which is leaking? Its easy to tell as your finger will get wet.
Once you know which it is you can go about fixing it.
You can go to your local speed shop and buy a new hose and clamp. You could use the old clamp, which is what holds the hose onto the pipe, but the ones you have are the old type which require pliers to get them on and off and cant be tightened. Get some of these clamps.
