Results 1 to 5 of 5
Thread: Running Temp
    Apr 2010
    redcliffe, brisbane
    Running Temp
    Hi guys i just got my car back on the rd but it seems to be running hot.
    i have the gti consol and gages installed and it reads just under 100..
    is this right? its been so long since its been on the rd i cant remember what temp it use to run at.
    any help would be great thanks
    Mk1 76 donor car
    Mk1 GTS 83 SA import,
    MK1 76 project
    Jan 2010
    Melb Westsideeeee
    I'm sure someone will correct me but but i do believe the fan turns on at 95, so i'd assume 100 is fine, but would be safer if the fan were too turn on a bit earlier to avoid it reaching 100.
    - Brown U.S import 81 cabby
    - 88 Honda crx b18cr
    Apr 2010
    redcliffe, brisbane
    Mine turn on at about 85
    Mk1 76 donor car
    MK1 76 project
    Oakleigh VIC
    Stock thermostat is 87°, that's the temp your motor should run at.
    Stock fan switch comes on around 90° - 95 °
    7? MK1 Caddy
    79 B1 Passat Dasher Project
    12 Amarok
    Apr 2010
    redcliffe, brisbane
    I put a new thermo in when I rebuilt it. could it be the wrong one and causing it to run so hot?
    Mk1 76 donor car
    MK1 76 project
