Page 4 of 6 FirstFirst ... 23456 LastLast
Results 31 to 40 of 55
Thread: Project :LOW-080: Mk1
  1. #31
    Sep 2009
    Chillaxing in Tas
    Quote Originally Posted by Water Boy View Post
    I so hope you leave the ouitside as is. Love the ratty look with those phat hotwires.
    thats the plan, even got a big arse dent in the hatch
    I will try and get more of the paint off the bonnet though,
    Yeah the hotwires look rather hot, they sit inside the guards rather nice with a little low and little camber
    <space for rent>
  2. #32
    Sep 2009
    Chillaxing in Tas
    need two tires, but here is a result
    <space for rent>
  3. #33
    Jan 2010
    Melb Westsideeeee
    I likey !! Dare you go low profile?
    - Brown U.S import 81 cabby
    - 88 Honda crx b18cr
  4. #34
    Sep 2009
    Chillaxing in Tas
    Quote Originally Posted by GeorgeMK1 View Post
    Ill be right
    Not much ground clearance as it is ahha.
    Only low profiles ill get is when i one day get 15x8 steelies, and wrap them in 195/45/r15
    <space for rent>
  5. #35
    Sep 2009
    Chillaxing in Tas
    Raised up 1.5", doesnt look it. but it is
    All wiring is in and working,
    <space for rent>
  6. #36
    Sep 2009
    Chillaxing in Tas
    added a few more bits today, was cleaning the shed and kept finding things it needed
    Raised it up a tad more aswell, it still has no engine in it so the front will come down.
    Random thing i noticed is the front passenger and rear drivers is 5mm lower then the other 2.
    Will this even up when engine in? or did this car have some chassis flex?
    <space for rent>
  7. #37
    May 2010
    NQ
    Does it have fuel or a battery currently in it?
    MK2 - *Insert list of dealer purchased extra's/standard features here*
    80 series - The MK2's BIG, Sooty, polar opposite...
    HAHAHA
  8. #38
    Sep 2009
    Chillaxing in Tas
    Quote Originally Posted by ryana89 View Post
    half tank fuel roughly,
    Ill sort it out once i got engine and battery in ect ect, i reckon it should even out. Probably needs a drive around block to settle aswell
    <space for rent>
  9. #39
    Sep 2009
    Chillaxing in Tas
    Still been plugging away at this,
    Add a few more bits to engine bay,
    Cleaned up a heap of parts.
    Pulled the 1.6L down, figured id slap new gaskets on one day,
    All seems pretty good, headgasket wasnt blown, but its cheap enough to do it while its out. gives me chance to paint block aswell.
    Will get the head face machined to make sure its flat before i chuck it back on when its ready to.
    Also undecided if i should paint the rims black, looks pretty cool in the photochop
    <space for rent>
  10. #40
    Aug 2009
    **** yes. Black that **** out!
    I'll make you a deal... when you paint your car I'll paint mine
    I wish I could say I've torn down my engine like that, would love to give the bay a proper go-over.
    Good work n that.
