Page 1 of 6 123 ... LastLast
Results 1 to 10 of 55
Thread: Project :LOW-080: Mk1
    Sep 2009
    Chillaxing in Tas
    Have had this Behind shed for a while now.
    Not wanting to scrap it as its too good for that, i decided i should attack it before it turns to ****.
    its a 19XX something 4 door, unsure what year as yet.
    Minimal rust, the worst is along the bottom seal. a small hole or two on floor. and a bit in passenger rear guard.
    Unsure what im going to do as yet, but it should be something as the following
    Repaint,
    Low
    Rims (unsure what yet,)
    1.8L on Digifant (want to try out EFI )
    Hidden wiring and battery in boot.
    Upgraded brakes,
    stock interior
    I have no time limit so it will be a slow process i reckon,
    really want to power in and get the main shell in Primer, will motivate me to get paint on her
    <space for rent>
    Sydney NSW
    Nial it brother seeing it in primer will be inspiring hope you have a great time
    May 2010
    NQ
    From that view the paint almost looks perfect!
    Looks like a solid starting point for a project.
    Best of luck with EFI (when you get there!)
    MK2 - *Insert list of dealer purchased extra's/standard features here*
    80 series - The MK2's BIG, Sooty, polar opposite...
    HAHAHA
    Sep 2009
    Chillaxing in Tas
    thanks mate,
    First step is to get what little rust there is fixed, all the holes in engine bay filled.
    And then car in primer. I have never painted a car before, but im sure going to give it a go
    Yeah Ryan, i really want to go something EFI, Might See if i can get hold of a Mk2 Engine and loom and go from there.
    Work has been slow, so Funds are small, and most of it goes into the Green Machine ATM. But sanding is Cheap
    <space for rent>
    Perth. WA
    just to let you know, leaving a car in primer ( unless its 2 pac epoxy primer ) still allows the metal under the primer to corrode, yep, its hygroscopic ie absorbs moisture...
    To spray in 2 pac you will need a proper booth and correct breathing apparatus, it contains isocyanates.
    HTH.
    Lots of MK 1 Scirocco's...
    Cheers,
    Grant...
    Sep 2009
    Chillaxing in Tas
    Quote Originally Posted by roccodingo View Post
    HTH.
    Yeap i know that, hence the Motivation to get it painted comment
    <space for rent>
    Jun 2007
    Eastern Suburbs Melbourne
    don't vother with digipants, better off going straight to a mk 3 set up
    i like volkswagens
    Sep 2009
    Chillaxing in Tas
    don't bother with digipants, better off going straight to a mk 3 set up
    Is that a direct bolt on manifold wise to a 1.8L?
    Injectors in head or actually on a fuel rail on manifold?
    <space for rent>
    Sep 2009
    Chillaxing in Tas
    Going to Make a start on this tomorrow if the weather is decent.
    Since having the green one off the road ive had a chance to check it out for rust, and its worse then i thought
    So everything good from green will make its way into this shell. Also cuts me down from 3 golfs to 2 LOL
    <space for rent>
    Sep 2009
    Chillaxing in Tas
    Did a bucket Load today
    Got green one stripped pretty well.
    Made a start on Red, Got all the doors on, started to do all the window rubbers, and tinted windows ect.
    Will do rest of windows tomorrow, try get some interior into her. and all the inside wiring.
    Will get pics tomorrow, not much to show atm
    <space for rent>
