Just remember, the lines are waaaay easier to remove while the car is stripped like it is now, and also, rust can be on the inside of the brake lines just as easily (if not more so) as the outside, because brake fluid absorbs water and it will corrode ferrous metal (steel), particularly if the car has been sitting, apart, or not driven, for a long time.
not trying to scare you into spending money, just FYI
The body looks beautiful.
'98 Mk3 Cabriolet 2.0 8V
'99 A4 Quattro 1.8T
