Hey man,
If it is advanced too much, you'll probably notice that its even noisier than before.
Taking the pump head off is definately a tricky job (well, putting it back together is anyway). I take it you didn't remove the pump top? (where the throttle lever is?). If not, then the governor will still be set the same, so you oughtn't have any problems there.
There are a lot of "little bits" in the head assembly that might possibly cause you problems - and the one i'm thinking of is a simple round shim about 4mm OD and 1.5mm thick that sits at the end of the plunger. If that didnt go back in it might be causing your run-on issue. (Its also possible you didnt even notice it, because it can just be stuck at the end of the plunger with the thin film of diesel and not fall off of its own accord.
In any case, going internal with the injector pump is a major psychological achievement. Well done.
'98 Mk3 Cabriolet 2.0 8V
'99 A4 Quattro 1.8T
