What static timing position have you set the distributor to ??
Does the vacuum canister have advance only or advance & retard ??
Try sucking on the vacuum line to the canister ( engine not running) to see if you have perforated the diaphram in the canister, check and mnake sure its moving the timing plate inside the dizzy as well...
