Mk3 bolts onto the subframe and is completely different.
Goto Pick and Payless armed with an old one and see what looks similar.
Does anyone know what the best power rack is to adapt to a mk1 manual?
I'm thinking of getting a mk3 set-up and i want to know if it can fit reasonably easily.
I know the linkage brackets are different but i can weld the old ones back on it.
Anyway, if anyone has done it, any advice would be great.
That was the plan, i've got a spare mk1 rack and i wanted to see if the rack less the arms was the same length and the streering column fit Etc. I know of one other guy doing it to a mk1, but i'm not sure if the lines interfere with the gear linkage
A golf 2 rack will fit with a bit of fiddling but the biggest hassle is mounting the gearshift brackets, or put in an auto or cable shift.
Widebody Cayman S Turbo, 83 ur Quattro
2000 996 C4 cab,12 Scirocco R OEM+ STG2+
72 914 (3.2S boxster pwr), 92 G60 Corrado
76 Scirocco(TFSI and DSG) 2018 Tiguan,Eureka,81 924.
Not an Auto, but a cable shift Mk3 box would be the go.Originally Posted by aprr32
at the moment i can get a mk3 set up, that's pretty cheap, but unfortunately it doesn't have a cable box in it. Thanks for the advice guys
Its all been covered before and the outcome was
Go to the Gym
come on guys the steering isnt that heavy on a golf its actually relatively light... it only weighs 800 kilos :roll:
its not for me, its so my woman can drive it too, the car has 15 X 7's on it with a small momo wheel, so when she tries to turn the car when its stationary, she struggles a lot.
The things we do for women
Please check out the past posts on this subject.
Advise you turf the silly steering wheel and 7 inch wheels.
I've had to do that for a female owner before ,cabs seem to be heavier than early LS's.I put 14 inch wheels,185/60 tyres and late Mk1 GTi steering wheel and a good wheel alignment.It was a vast improvement but still not like PS.
The closest thing would be a LHD 944/924 rack.Notice I said LH
good luck
