Results 1 to 10 of 24
Thread: Carby choices
    Feb 2007
    Eastern Melbourne, VIC
    Carby choices
    G'day guys, I've been searching the forums, cant really find what I'm looking for.
    I'm thinking about getting a decent carb for the 1600 I'm planning to chuck in that I have sitting in the shed (thanks again Golf Loon ), but i honestly have no idea what kind of changes different carbs will make. I was reading Bluerex's post a while back about a 45dcoe on his motor, what kind of performance would this add compared to the stocker on it now (dont even know what size the stock one is)? How would this compare to a twin 40dcoe setup? I also have extractors that will be on this motor, just looking for some decent get up and go at the lights.
    Damn carby cars, dont know a bloody thing about them
    Cheers!
    The Baltic Bruiser™
    Jun 2007
    Eastern Suburbs Melbourne
    i dont know much about carb either, but i figure the twin 40's will give more power, as they'll be able to flow more than a single 45? seems to make sense, but im not 100% sure! have you thought about going K-jet, (apparently) it will give you more power and better economy, and i thiknn you can get up rated injectors (off a volvo 740t or something) and that wil give you more than enough off the line.. sounds good in theory, but probably costs a fair bit more no doubt! hope that resembled help!? haha
    have a good one
    i like volkswagens
    Oakleigh VIC
    The stock carby is pretty restrictive and is renowned for idling issues.
    I run a weber DGAV on a passat manifold. This is a good first step. It performs better than the stock carb as it is a two barrel setup, being progressive the second barrel only opens at full throttle which should , in theory , help with fuel economy. The DGAV is a downdraught carby. It also has a choke for cold starts which can be setup as electric or manual.
    Next step up is a single sidedraught Weber DCOE or the Dellorto equivalent. Faster but no choke and might use more fuel.
    Twin sidedraughts is the best carby performance option but economy and cold starting might be a bigger issue. Twin Webers look and sound fantastic!
    I'm sure others will chime in with venturi and jetting issues as required
    You've opened a can of worms with this one!
    Pretty much any carby is better than the stock 1600 for performance!
    Pete
    Nov 2005
    newcastle
    Any upgrade to the standard carby will be good for get-up-and-go, you will use more fuel though. My yellow mk1 1.8 has a 45DCOE (sidedraft weber) on it, and its awesome. My white one has a 1.6 with a 40mm dellorto, but im yet to see how that goes on the road as its currently interiorless.
    The twin carb setup gives you 4 throttle bodies (about 4 times the inlet area of your current setup) and thus gives you more air+fuel, which equals a heap more kick. sounds awesome too
    btw.. the weber dcoe and dellorto dhla range have manual chokes for cold start
    I still have two 40mm DCOE carbs for sale if you are keen, just let me know.
    TDI mk1 on the road!!
    Oakleigh VIC
    Quote Originally Posted by mollins View Post
    Cool, happy to be corrected on that score.
    All the more reason to go sidedraughts!
    Pete
    Gosford Central Coast NSW
    hey pete, you dont have another DGAV and matching manifold do you? i'd like to give something like that a go.
    '98 Mk3 Cabriolet 2.0 8V
    '99 A4 Quattro 1.8T
    Oakleigh VIC
    Not at the moment, but they're pretty common. Put the word out for a passat TS manifold in the wanted section and you'll soon find one. I think the DGAV was factory fitted to the 2.0L Cortinas (I might be wrong on this , anyone?) so it shouldn't be too hard to track one down.
    There's a pic of mine in another thread, hang on a sec, here it is...
    You can make out the choke cable running back through the firewall. The car was originally a diesel so there was a bracket for the choke (cold start valve in the diesel) on the column.
    The original throttle cable works with a bit of fiddling about.
    Pete
