This is my wiring chart we went off when we did my mates mk3/seat 2.0l 8v conversion using mk1 Gti 8v dizzy and module
Pin 1 - Green, Ign. coil earth
Pin 2 - Brown, Earth to the body/battery
Pin 3 - Brown/Yellow, Distributor 3 pin plug. Pin -
Pin 4 - Black, Ign. coil power
Pin 5 - Red/Black, Distributor 3 pin plug. Pin +
Pin 6 - Green/White, Distributor 3 pin plug. Pin O
Pin 7 - Blank
Pretty sure any early mk1 - mk2 module will work, Im guessing the dizzy you have isn't a vacum advance item??
You have to run a vacuum advance dizzy for this setup to work (can buy brand new on ebay USA) and you need to swap the dizzy gears over back to original mk3, otherwise you have to run a electronic vacuum advance deal like i run on my 2.0l 16v they also float around ebay i have part numbers laying around and wiring diagrams for that to.
