I'd try higher octane fuel first.
Other things you could try
Colder plugs
enriching the mixture
Colder thermostat.
Pete
Guys my car is pinkking under load.
Seems fine when cold but no so good when warm.
I know these old girls are prone to it.
I have set the timing up 6 deg retarded for unleaded.
Running standard unleaded, not 10% ethanol.
Just increased the ratio of coolant to water.
But still cannot cure it, any advide welcome ?
1993 MK1 CAB ! Work in Progress........
Colder plugs
Colder thermostat.
Pete
I've heard K-jet and water doesn't mix at all. So maybe chuck a cap full of metho down the tank, to "absorb" any moisture...
Other than that, it's possible you've just got a dud tank of gas. Unless this has been happening for a few tanks?
Most people recommended big brands, shell, BP etc try whack in some 98 (VPower, or whatever they call it) for petrol.
Or even a bottle of octane booster will lift up the numbers if needed.
I got that metho cap in the tank trick, from a very reliable source. He did it to his car's about once a month, just to stop any water/moisture stuffing up his K-jet.
Unless anyone else has anything bad to say about it?
She is running too lean or isnt happy with the fuel mate. My opinion would be to reset the timing for premium and run it on 98plus. Colder thermostat will lower the core temp of the engine and keep the cyl temps lower but experience with Kjet would say its fuel. They dont like crap fuel and low octane either. Timing and premium would be my first move mate.
CHeers
JMac
Alba European
Dont run it on 91 octane. Are you crazy?
98 thats it. It costs a bit more, but you go further so it works out the same.
Australia runs on 3rd world petrol, thats why its so cheap. Its actually a couple of octane points lower than european equivilants. Thus aussie 98 is probably the same as German 95 and the 91 you are putting in is really 88.
Lots of euro cars are detuned for aussie petrol when they are shipped here.
Put in the good stuff and I reckon you will notice a difference and will never go back.
06 Jetta 2.0TFSI Killed by a Lexus!
09 Eos 2.0TSI DSG Loved this car but has now gone to a new home!!
14 EOS 2.0 TSI has arrived!
