Page 4 of 6 FirstFirst ... 23456 LastLast
Results 31 to 40 of 54
Thread: This Picture Need A Topic Of Its Own
  1. #31
    Jun 2007
    Eastern Suburbs Melbourne
    Quote Originally Posted by datzed View Post
    Quick question guys,
    Will 15 x 7 ET28 4x100 wheels fit under MK1 Guards without lipping? Depends on ride hight I know but perhaps with 3/4-inch lowering?
    only 3/4 inch lowering?!? that's not even a whole coil! If you're car's on stock suspension sure it'll fit, but look mighty bad! Rolling the lips isn't too painful a job anyways.
    i like volkswagens
  2. #32
    Aug 2005
    Quote Originally Posted by Spyda View Post
    Undrivable because.......?
    IMO over done, looks stupid when the rim is THAT far from the tire.
    A Mk1 literally doesn't work safely at that height. The steering geometry goes up sh-t creek (bad bump steer; no front end travel whatsoever; bad CV angles, and darty, nervous steering). Both would also have bad arch rubbing.
    At the end of the day, though, neither is build to drive properly, so it's not really an issue.
    I like both of them
  3. #33
    Feb 2008
    Melb
    Jarred, I'll likely lower it about 1inch or thereabouts but I dont want it riding as low as the two in the first post. While they look absolutely off the hook, they'd be far off that driving on a daily basis.
  4. #34
    Jun 2007
    Very true! 1 Inch is fairly decent lowering. I doubt you'd have any issues. in reality you could lower it two inches and still not run into any (or much) trouble.
    i like volkswagens
  5. #35
    Nov 2005
    drop it 105mm like i did, slap 16's onnit and i still dont have rubbing issues
    wabit
  6. #36
    Feb 2008
    Melb
    Its not so much the rubbing issues but ground clearance. While a slammed stance is great, I dont know if I could go with the compromise of driviability (ie going angeled over bumps constantly etc).
    Still thoughts at the moment but I'll most likely drop about an inch and have the wheels poking out of the guards about 10-15mm with spacers to give that slammed/pumped look without actually being that slammed.
  7. #37
    Jun 2006
    Orange NSW
    My goof was (was- its not on the road at the moment) lowered 2.5 inches. 15x7 et 26 BBS wheels. Would have rubbed on the lip if it wasn't folded but otherwise sweet as.
  8. #38
    Feb 2008
    Melb
    Preen59, how was it for ground clearance (ie did it scrape over the usual speed bumps etc)?
  9. #39
    Aug 2005
    Quote Originally Posted by WABIT View Post
    wabit
    I didn't think your car was even driving, Dom
  10. #40
    Quote Originally Posted by Valver. View Post
    i was going to say that
    Velly
    '91 2.0 8v GTI
    Quote Originally Posted by DubSteve View Post
    I have wood thinking about you
