custom 13mm to get the nuts off Gemini intake manifold to get carby off
have had it for years
<space for rent>
Only challenge I see here is the fuel lines, you won't get diesel through the smaller petrol lines.
Best if you swap out the tank and fuel lines too.
Pete
had a look at that, my golf was diesel to begin with, so it has the right tank, but comparing lines to my parts car (diesel) my green one has one big line, 1 small, parts car has 2 big lines.
So going to pinch the big ones and clean them up. SHould be easy
if not i got 2 diesel tanks lol
<space for rent>
So im thinking one of the previous owners not only swapped lines, but tank too !!
Its a side feed tank with the fuel level sensor on the side too.
My parts car which is diesel is also a side feed, but the pipes are in different spots and the sensor wires are not on the side :S
Ill go out and grab some pics later
Edit,pics
This one is from Diesel Car
This one is From my Petrol car (ex diesel )
From what ive read its only the diesels that had a side feed tank
<space for rent>
do it! Swap it back to diesel! Low and slowww
My Blog:
tinkererstales.blogspot.com.au
thats the plan, low slow and sooty
should have the diesel in later next week. hoping to pick up the last donor car and engine on tuesday!
<space for rent>
turns out the tank was also swapped when converted to petrol, not to worry. i has a diesel tank or 2
Gives me a chance to clean one out and make sure its good, also got a chance to check filler neck, looks new!!.
Do i have to remove the rear beam to get tank out? if so, where would i hold the car up on axle stands while doing that?
<space for rent>
- You may not post replies
- You may not edit your posts
Forum Rules
