Don't try and do it off a longitudinal engine. My advice would be the AGU from a MK4 Golf or A3. Easier if you use the 020 box but way up in scene points if you fit a cable change box and convert to hydraulic clutch.
Fit the engine loom and OBD plug for proper diagnostics. Then get me to defeat the immobiliser and use the factory ECU. You can then run tried and tested tunes in it.
Qpeng has a load of information on their site.
