Is your indicator centred? Sounds like an issue with the euro parker setup.Check wiring behind the emergency flasher switch and indicator stalk as well as fuses.
Pete
Hey Guys
Just wondering if you could help me, in the mk1 I have a weird issue with the park lights, more the left hand side park lights.
Its the front and rear actually. When you turn on the park lights the front parker in the headlight doesn't turn on
And either does the parker in the rear left tail light
I checked the globes and its not that so I'm thinking is it a fuse or something? As the right hand side is fine so not sure what it is
Help appreciated!
Thanks Steve![]()
Pete
Easy fix I reckon.
Best buy a test light or voltmeter!!
fuse...
Thanks Guys
Andrew Fuse?
yes, more than positive, easy find with a testlight and an easy fix if it is!
Yep thanks sorry didn't quite know what you meant my just that will check soon thanks guys![]()
