Page 1 of 3 123 LastLast
Results 1 to 10 of 24
Thread: Painting Techniques
    Painting Techniques
    i need some tips on painting in order to get a nice glassy finish that i want when i respray the two door this coming holidays.
    i resprayed a panel on the four door and it came up dull i was told that this was because i didnt put cutting compound on the 1st layer of coulour befor the clear laquer. and it was warm enough.
    Sunny Coast - The QLD
    Last time I painted a car I used presure packs so I cant help you. And if I do offer advice tell me to get stuffed coz I know nothing about paint, other than it stops my car from rusting.
    MK1 floG soon to have 16v 2L with cable change gbox - need a 16v turbo manifold
    "Fit the gearbox ya bum." Loon - best post ever!
    then why reply?
    Camden, Sydney
    I`m a horrible painter man, spend the money on a pro job.
    Do the prep work and then spend the money.
    Or have a matt black one!
    sydney/ cessnock
    some painting tips but this is hard work
    the first Q is 2pac or acrilic (cant spell)
    i did mine in acrylic but this takes far more time and prepareation
    always stick with the same type of paints lots of paints react with each other and craz
    so once u have done any rust removal and welding (welding can warp pannels better to treat and fill small non structural rust) primer using a filler primer couple of coats then do a mist spay over the area and rub back with block & with 800 wet sandpaper (this shows any highs and lows) .
    colour long even stokes keeping gun the same distance away for the entire stroke. with acrylic u can cut it back with compound or 1200 paper before clear and after clear carful when using a buffing pad on large grinder doesnt take long to buff back to primer on a corner. hope this helps. painting is a lot of work 2 pac is ment to be easier
    owned a number of mk1 golfs have a collection of spare parts project golf is a 78 2 door
    im just gunna respray the original colour. is 2pac a different kinda paint?
    thanks for the tips!!
    Golfwise Guest
    painting
    2 pac is too difficult at home and is very unforgiving whereas acrylic doesn't have the shine but will dry off quickly and any boo boos can be either touched up or rubbed out with fine paper before buffing.Using clear over your colour can give a 2 pac look.
    Acrylic is a lot more work but user freindly.
    Gosford Central Coast NSW
    if you do it right, enamel can give you a nice gloss too. plus its cheap and is great for protection and practicality - probably it'll never look as good though.
    if your going original, im pretty certain that most every mk1 would have had a baked enamel finish. baking is hard at home, but you dont have to do it....
    pick a good day for it - my golf doesnt look all that great after only 3yrs with the enamel job i gave it, but the weather could have been better and i only used 2L of paint to do the whole car...should have been 4 or 5 i reckon.
    good luck
    '98 Mk3 Cabriolet 2.0 8V
    '99 A4 Quattro 1.8T
    cheers mate.
Similar Threads
  1. It's Baaack..... return of the Rally Golf Pt1
    By Bluerex in forum Mk1 Golf
    Last Post: 03-01-2008, 08:49 AM
  2. Roll Cage Painting....sucks!
    Last Post: 16-03-2007, 07:52 PM
  3. Audi S3 brake upgared (Caliper painting)
    By PoloGTi in forum Polo (9N & 9N3, 2002 - 2009)
    Last Post: 26-11-2006, 01:42 PM
  4. wheel painting? where does it?
    By Red Mk1 in forum Bodywork/Trim & Detailing
    Last Post: 11-06-2005, 11:33 AM
