Page 31 of 34 FirstFirst ... 212930313233 ... LastLast
Results 301 to 310 of 335
Thread: The one...
  1. #301
    Oct 2013
    ACT
    So I might have a 2door shell coming my way soon. If that happens I can then get the engine(1.8T) in and start cutting and chopping my body etc to fit the quattro system.
    Only The Good Die Young 45
    For a better ride, go WIDE!!!
    VS Commodore V6 Berlina- FOR SALE
    1979 Golf Mk1- http://www.vwwatercooled.com.au/foru...one-92128.html
  2. #302
    Oct 2013
    ACT
    I have a 2door coming my way with apparently not bad rust. Just surface rust. Whoop whoop
  3. #303
    It's about time you had some good luck. Are you still planning to do the AWD conversion?
  4. #304
    Oct 2013
    ACT
    Hell yeah, I have the starting kit for it:
    Engine and gearbox mounts.
    Steel to build the frame for the rear diff
    And all the parts
    The one...The one...The one...
  5. #305
    Oct 2013
    ACT
    Once I have the shell, I will install the motor and gearbox as is, and then work from the back the get the drive shaft line right.
    From there I will need to start working on the strut towers at the rear first, that way I can maybe have the car's back on the ground.
    Might have to recruit some Canberra boys and Paul for a few saterdays where I will supply beer for a few extra hands.
  6. #306
    No worries. I'd love to help and tell you what to do while I sit back and watch.
  7. #307
    Oct 2013
    ACT
    Haha
    When did you become a comedian?
  8. #308
    Oct 2013
    ACT
    So we picked the golf up and dropped it off at Shadow_Rusty's place.
    Just a quick pic:
    The one...-imageuploadedbytapatalk1426292647-549285-jpg
  9. #309
    Love that colour.
    Have you had a chance to check out the usual rust spots?
  10. #310
    Oct 2013
    ACT
    Yes, all looks good. There is one "ugly" spot in the left wheel arch but should be able to repair that easily. I will have to find a passenger door. And I will have to replace the front end, but outside of the needed fabrication to make the setup fit and work, there doesn't seem to be much else needed.
