When do you want the car trailer?
Printable View
Friday if possible, and I'll bring it back early saturday morning??
And uhm... Engine is out, and waiting... And I can't seem to find the door handles... Will have a look around through all the stuff in the shed when I have more time doing so...
Only The Good Die Young 45
Can you guys tell me where I can buy all the mounts for this 1.8t motor to fit in my Mk1.
Already done a bit of checking and I am gonna swap the floors over so that I have the sub-frame mounts and also the transfer box mounts in the right place.
Need help, pretty urgent as I am possibly starting with all this on sunday and would like to order the mounts and while waiting for them I am going to do some body work and get the floors transferred and engine bay cleaned out and smoothed.
Will get dad in with the welder to make just go over the weld coz he can weld much better than me.
And I was thinking of doing the sleeper look... Bigger steelies but also stretched, and just try and keep it as plain as possible.
Just Caddys or Crazy Quifs.
I found the Crazy Quifs ones didn't fit too well and I ended up modifying them.
MK1 Golf, Jetta, Caddy & Scirocco 1.8T 20vt TDI 02J Engine & Gearbox Mount Kit | eBay
Items
If you're using 02A/02J there are also these mounts but this is just for the gearbox not the engine. I used these and they were pretty good. @@ Seilzug Getriebehalter 02A Golf 1 G60 16V Turbo @@ | eBay
Well, as if things couldn't get worse, I have to postpone my trip to pick the S3 up until somewhere around the 15th. No trailer available in canberra for two weeks...😡😡😡
Other than that, I found an awesome thread on another forum and this guy is busy with what I want to do:
http://www.ttforum.co.uk/forum/viewt...+powered+golf]
He is pretty handy with tools as well, and I have been browsing around on that forum for some ideas as well and there is a few things that could help in the golf build. And that is from cosmetics to performance etc... Maybe this forum could be help for some you guys.
Pulled the spark plugs out to try and start the golf but the starter motor still just makes a click noise and doesn't turn at all...
Check the motor by turning it on the crank pulley again and she turns very smooth and no hick ups...
NEED HELP FIGURING THIS OUT, please someone help... Would really like to sell a running motor to a forum member, rather than them having to spend more on the motor...
Sounds like the starter is gone dude.
Or are you sure there is enough power going to the starter?
Well, I have the starter in it which I bought of you foff and have had some jumper leads on it to see if the battery is the problem, but she still only pushes out and makes the click sound for when it pushes out.
Sent from my iPad using Tapatalk HD
Battery
