I have a 2door coming my way with apparently not bad rust. Just surface rust. Whoop whoop
Only The Good Die Young 45
So I might have a 2door shell coming my way soon. If that happens I can then get the engine(1.8T) in and start cutting and chopping my body etc to fit the quattro system.
For a better ride, go WIDE!!!
VS Commodore V6 Berlina- FOR SALE
1979 Golf Mk1- http://www.vwwatercooled.com.au/foru...one-92128.html
It's about time you had some good luck. Are you still planning to do the AWD conversion?
1978 MK1 2.0 16v http://www.vwwatercooled.com.au/foru...-46488-70.html
1991 MK2 GTI 2.0 8v, white (RIP) and it's red replacement http://www.vwwatercooled.com.au/foru...gti-42078.html
1997 MK3 CL http://www.vwwatercooled.com.au/foru...ml#post1292061
2001 & 2002 Bora 4motion. http://www.vwwatercooled.com.au/foru...st-123823.html
Hell yeah, I have the starting kit for it:
Engine and gearbox mounts.
Steel to build the frame for the rear diff
And all the parts
Once I have the shell, I will install the motor and gearbox as is, and then work from the back the get the drive shaft line right.
From there I will need to start working on the strut towers at the rear first, that way I can maybe have the car's back on the ground.
Might have to recruit some Canberra boys and Paul for a few saterdays where I will supply beer for a few extra hands.
No worries. I'd love to help and tell you what to do while I sit back and watch.
Haha
When did you become a comedian?
Love that colour.
Have you had a chance to check out the usual rust spots?
Yes, all looks good. There is one "ugly" spot in the left wheel arch but should be able to repair that easily. I will have to find a passenger door. And I will have to replace the front end, but outside of the needed fabrication to make the setup fit and work, there doesn't seem to be much else needed.
