Results 1 to 10 of 11
Thread: Oil Pump
    May 2006
    Maryborough Vic
    Question Oil Pump
    Oil Pump where is the best place to get a new one ?????
    AND a new front engine mount or rubber
    or has any one converted to a stronger one
    talking about the one that goes to the radiator support panel
    Boronia VIC
    Quote Originally Posted by ontarv View Post
    Hanvic South Yarra or someone local that buys from them for the oil pump.
    http://www.hsy.com.au/
    otherwise ebay or www.germanautoparts.com
    Front mount I run a SuperProPoly one. I got it from SupercheapAuto.
    No particular issues with running the urethane mount.
    Pete
    Jun 2006
    Orange NSW
    Check Ebay for Prothane bushings. You can get an entire set of bushes including all engine mounts for US $70.00.
    Can't go wrong.
    Get a diesel/16V oilpump if you need a new one. Higher volume and pressure won't hurt.
    May 2006
    Maryborough Vic
    Thumbs up
    thanks will look around at those places
    my relief is stuck ok when it is hot
    but about 110 psi at 2500 rpm when cold
    will build up enough pressure to make engine break down at
    revs when cold
    Perth. WA
    Techtonics front mount, for the street...
    http://www.techtonicstuning.com/show...artnum=199.100
    Quality products and great company.
    Lots of MK 1 Scirocco's...
    Cheers,
    Grant...
    May 2006
    Maryborough Vic
    Unhappy
    still no luck with oil pump
    hanvic no longer have then
    german auto parts only list mk2 on
    any other ideas !!!
    Jun 2006
    Orange NSW
    any other ideas !!!
    Techtonics Tuning.
    Oil Pump with 30 mm gears for Solid and Hyd lifter 8v cars
    http://www.techtonicstuning.com/show...artnum=115.205
    2 liter hyd. oil pump 36mm gears-8V engines
    http://www.techtonicstuning.com/show...artnum=115.206
    Oil Pump for 2.0L16V engine 36mm hi-volume-German
    http://www.techtonicstuning.com/show...artnum=115.208
    sydney
    i have a poly front mount if you are interested??
    I would have gotten wood from the picture message you sent me.. But I was sniffing Nitro, so i already had it. Hahaha.
    Apr 2006
    Hobart,Tas
    Ihave 2 deisel oil pumps in transit and shoulfd have them here by friday.
    cost $100 plus freight
    Andrew
    Boronia VIC
    There are no MK 1 Golfs in the US, there are RABBITS!
    Have another look at germanautoparts under Rabbit.
    http://www.germanautoparts.com/Volks...t/Engine/151/1
    Andrew's offer above is good too! From memory the diesel pumps have bigger gears.
    Pete
