Results 1 to 5 of 5
Thread: oil pressure guage on mk1
    Nov 2005
    newcastle
    just wondering where to connect the capilary line to read out the oil pressure?
    TDI mk1 on the road!!
    Camden, Sydney
    There are a few possibilities. If you have a blank or unused sender on the top of the oil filter thats the best. Or on the end of the clyinder head above the gearbox. There will be either a sensor or a blank there too.
    imported_brackie Guest
    "T"
    If you want to keep your light when using the cylinder head sender aperture, buy a "T" piece. They're available from most accessory stores and some engineering and plumbing outlets.
    sydney
    i ran mine from the out let on the side of the block with a t piece to retain the factory sender
    just confused me that damm gauge
    I would have gotten wood from the picture message you sent me.. But I was sniffing Nitro, so i already had it. Hahaha.
    sender should be on the head if possible as you want to know that there's press to the top of the motor. As for the spare you could put an oil temp gauge in near the filter which would give you an idea also that the general temp of the car is incheck.
    Cheers Dave
    __________________
    :twisted: crazy mk1 16v :twisted:
Similar Threads
  1. VR6 Fuel Economy / Tyre Pressure Quiz
    By gman in forum Mk3 Golf & Vento
    Last Post: 10-03-2007, 07:51 PM
  2. gti boost pressure??
    By gpk_gti in forum Mk4 Golf & Bora and New Beetle
    Last Post: 04-03-2007, 08:02 PM
  3. tyre pressure help
    By Veee1.8t in forum Polo (9N & 9N3, 2002 - 2009)
    Last Post: 09-01-2007, 07:29 PM
  4. Bora - Oil Pressure Warning
    By pursuit_ute in forum Mk4 Golf & Bora and New Beetle
    Last Post: 20-10-2006, 10:41 PM
