As I was telling Dom yesterday…. you have two options with the front panel, both of which are available from VW. You can get the entire front panel for around $300 or just the lower front skin for around $200. In most cases you only need the lower front skin
To remove the old front panel, drill out all of the sport welds with a spot weld drill bit. Then it is a case of butchering the old front panel to get it off, before cleaning up the surfaces with a grinder.
This is what was left after I butchered the US spec front panel on the caddy:
You have a couple of options for attaching the replacement front skin. You can have it welded on or use a metal bonding adhesive such as Lord Fusor. This is the way most of the modern manufacturers are going these days, especially for simplistic panel work.
Either way, you’ll need someone to give you a hand or a heap of G clamps
New front panel attached:
Look forward to seeing further progress this weekend, Dom
