should work as long as the solinoid has enough pull
might have to make a counter lever if it doesn't
well i dunno but ive got the idea of a commodore boot release hooked up??
would that work??
wabit
well it has to open up a full sized boot.... upwards in a commo....
my cabby boot pops out sidewards
wabit
yea logic says it should work. tail gate looks sweet as in the 'chop. will def go with your style!
it just depends on where you can attatch the cable for
the solinoid , if the lever on mechanism is short it could be
too hard for it to pull ?
the commode mechanism is disigned to have this option
so where you attatch the cable , it has good leverage
but it should work just might take more fiddling
i might be running a couple bonnet gauges.. but dont worry there not chrome ones... there gonna be there for a purpose... for legal issues i cant have one of them inside the car, the cups will either be black or color coded white
wabit
interesting choice with the gauges. as if you cant run them inside, legally?
door handle looks good but.
out of the TWO the ONE im running is fuel pressure... its mechanical so i cant have fuel running inside the car
wabit
