Results 1 to 10 of 10
Thread: Not selecting 4th..... eh??
    Sep 2009
    Chillaxing in Tas
    Ok,
    In middle of putting a new motor in golfy, and i started on the links. i made sure box was out of gear, and shifter hasnt moved. (i hope anyway)
    Now it will select 1st 2nd and 3rd, and reverse. but 4th wont go in, is very tight.
    I undid links and tried selecting 4th by hand on the box and it still wont go in, so its not a link problem. this box worked perfect about 5 days ago before i pulled it out of donor car...
    Any ideas? im stumped.
    <space for rent>
    Apr 2006
    Hobart,Tas
    Possible stray speedo cable plastic drive inside the box?
    Sep 2009
    Chillaxing in Tas
    does that invlove pulling box out?
    <space for rent>
    Apr 2006
    Hobart,Tas
    It does as its a plastic part but you need to ascertain whether that is the problem. It may have been moved from its spot in the box while the box was out. I had a stray one in a car here years ago that decided to shift itself and jam up certain gears, ie. reverse as I was trying to get it off the hoist.
    Ifr you cannot get top gear with all the linkages off, I would guess that that is your problem there.
    Anyone else have any ideas?
    Sep 2009
    Chillaxing in Tas
    well that sucks ass bad!!!!
    Just got the engine in finally
    So ill have to pull box apart to get it?
    <space for rent>
    Sep 2009
    Chillaxing in Tas
    all fixed..... hopefully
    <space for rent>
    Apr 2006
    Asaka-shi Saitama Japan (from Tassie)
    make shure nothing is in the way of the selector forks....
    like Doms dodgy brake line on the beige one...looped around...
    other than that, take the link off the main input and see if u can select 4th from there. if so, u need to ajust the linkages.
    Cheers, Benny
    www.axesent.com.au
    Sep 2009
    Chillaxing in Tas
    i couldnt select 4th from the box without links. just moving the shaft by hand.
    All good now, just put my spare 4 speed in.
    <space for rent>
    Nov 2005
    so did you establish if the speedo gear was dropped in the box?
    are you sure that your selecting 4th gear position correctly with the linkages off?
    MY16 MKVIIR - Option: Folded rear seats mode.
    MKI....#14....lost count.
    Sep 2009
    Chillaxing in Tas
    yes i know where each gear is
    had my bro **** gears while i watched links, reverse easy to find cause it "clunks" into place
    Not sure what problem was, but with spare box i could turn the diff flange easy and the other one would turn opposite direction.
    With the box that lost 4th its stiff as, even out of gear,
    <space for rent>
