Results 11 to 20 of 21
Thread: Normal MK1 compared to MK1 Gti
    syncro Guest
    First GTIs were made in 1976.
    First RHD GTIs were made in 1979.
    1976 GTIs had a funny oil cooler, not the beetle type.
    Andrew Cowan entered a GTI in the 1976/7 Southern Cross Rally.
    I have a 1977 GTI brochure (8/76) that is in English.
    Nov 2005
    i gotta k-jet 8v gti engine from the U.S YAY!
    JUST WANTED TO ADD ME SHARE
    wabit
    The 1.8L came out in 9/82 there are a couple of physical differences,
    - sump I believe is different - larger capacity
    - top radiator hose outlet is between cyl 3-4 (1.6L cyl 1-2)
    - 2L engines I think are a couple mm's taller in height but I may be wrong..
    GTI's are 20mm lower than standard, bilstein shocks standard
    wider steel wheels before alloy's were standard
    Different interior - seat(checked style trim upto 9/80 then went to striped)/ carpet style & material, new style dash from 9/80
    just to name a few.
    It's all relatively small difference's but it is easy to build a replica.
    I'll try and find the GTI history and pm'd the link if you like
    syncro Guest
    Dash is made from hard plastic
    Black A pillars
    sway bars
    green tinted windows
    non opening quarters
    no padded door capping
    fuel tank is same as diesel tank
    Sep 2005
    Well turns out that the golf ive been looking at isnt a gti despite all the things that make it look like one! Thanks to some guys on here for running engine numbers etc!
    Im unsure if i should still pick it up, needs a fair bit and i dont know what the engine etc is even like!
    Are the gls easy to work on and what are they like with a fairly standard engine it was only ever ment as a toy to go to uni in and few twists! Was a bonus if it was a genuine gti
    Camden, Sydney
    The engine is the easiest bit to fix. I`d be more interested in checking that it had no rust in the floors etc. If you are not worried about originality, you might as well get one that someone has modified and spent lots on for cheaper than a stock one. No one except a purist can tell if its an original GTI or a lookalike and it doesn`t really matter as a drivers car, both are great fun.
    Quote Originally Posted by syncro
    F
    What you mean this one?
    Used to belong to a friend's dad. I have been using it as inspiration for my own project.
    C
    Last edited by Bluerex; 25-03-2007 at 07:41 PM. Reason: re-located missing picture
    It's been a while...
    syncro Guest
    Andrew Cowans went back to the UK?
    There was another one built here from a LS (Kevin Bartlett?) for the Southern Cross. That one was RHD.
    Long time ago and memory is fading
    I should say that the photo and Dave's recolections are keeping my spirits up. His dad owned 2 GTI's I think Kevin was involved too.
    C
    Don't s'pose you have any colour pics? I will be doing mine in similar red and blue on white (but without the Selley's sponsorship)
    syncro Guest
    That's a big ask! I probably have some slides that I took as I was always into Golfs. Unfortunately it only lasted 1 night until it broke a CV or drive shaft or something. I remember speaking to him about his choice of cars and was always sceptical if the Golf was suitable for Australian rallies.
    Do you know what happened to it and the other one? Did the KB one end up in Chris Heyer's hands for Bathurst or is that another replica?
Similar Threads
  1. Are Oil Leaks Normal?
    By auspassat in forum Passat (B4 & B5)
    Last Post: 09-03-2007, 08:20 PM
