Noisy Lifters, ATF Trick DIesel Trick?
Hey all
Got a problem with a noisy Lifter, it comes and goes. worse after a 15 min town drive.
Matt (Golf Loon) suggested 500ml of diesel in oil, run at idle for 15 mins, few revs. then drop the oil and filter.
Also read if you drop a Litre of Oil and Replace it with ATF (automatic Transmission Fluid) 1L and run it for up to 100kays if not more, then drop the oil it should clear out all the gunk built up.
Any Insights?
On a good note, the 1.8L is amazing in a Mk1
<space for rent>
- You may not post replies
- You may not edit your posts
Forum Rules
