You should point out that your Audi runs K-Jet!
Check the pump's still bolted up under there. You might also need to check your lift pump ( if you have one) in the tank is OK.
The bearings in the pumps do eventually fail.
With mine the pump would sieze (usually mid corner uphill in the wet) a tap with a hammer would get it spinning again but in the end there was no option except to replace it.
Locally a pump is about $300 but I've seen new ones on e-bay for around the $100 mark.
Pete
