I have figured out the classing, it is not registered as a Golf GTI but as a Golf, meaning that it dosnt have to have the heron head, meaning the late model 8v can be used (because displacement change is allowed it is not a problem).
The minimum weight for P2 which is up to 1600cc is 880kg if i remember correctly (maybe 900) and it is the same for up to 1800cc, over 1800 is 980kg
The cage is all chrome molly, so its not as heavy as it could be, but it does have a lot of bar work, mate of mine in qld is running 960kg, but we re did the floor in 3mm plate cause he planned on going to 2ltr. There isnt much more weight to be taken out (easiest way is by swiss cheeseing the bar of the trailing arm)
76' Mk1 Rally Car, 1800 8v haltech ecu
94' Fairmont Ghia, v8, big cam, leather, perfect for towing golfs
89' EA ex taxi, lpg, cheap and easy
