Results 1 to 9 of 9
Thread: New wheels
    Now Adelaide!!!
    New wheels
    I have seen a set of wheels that would match the PCD of the Cab i am buying.
    They are 16x7 size dont know the off set but can someone tell me what will fit?
    Also what size tyres should go on them to keep the speedo accurate?
    Thanks for any help.
    Rob
    Jul 2005
    Newcastle, NSW
    et28 - no idea on tyres as I only ever have run 15" on my MK1s.
    Gosford Central Coast NSW
    you can get 195/45/16. They would be OK, but 16's look huge on a mk1. Good luck though!
    I once ran 16x7.5 et35 on a mk1. It looked a bit silly, and the rear was prone to rub.
    I think you can get 195/40/16. These might be better for fitment but will be very stiff coupled with low suspension.
    '98 Mk3 Cabriolet 2.0 8V
    '99 A4 Quattro 1.8T
    Now Adelaide!!!
    Thanks for your replies might have to look at some other 15s then.
    Cheers Rob
    Mar 2007
    South Brisbane
    Quote Originally Posted by rob64981 View Post
    Cheers Rob
    Ive always ran 16x7s on my mk1s offset +40 or +35 will be fine without rolled guards fits under standard struts fine. with coil overs for need to run a 5 mm spacer if the offset is +40. as for tires i currently run 195/40 i used to run 205/40 with no problems.
    Now Adelaide!!!
    Thanks Revnit for your help.
    Rob
    Jul 2005
    Newcastle, NSW
    What do they wheels look like more importantly. If they look crap your wasting your time
    Now Adelaide!!!
    Quote Originally Posted by mikinoz View Post
    Hope these meet with your approval
    Obviously they would get a new shiny coat of paint.
    Rob
    Ballajura, W.A
    Im running 16"x7" with an offset of 45 and 195x45xr16 needed 10mm spacers on the front to stop rubbing on the brake caliper but fitted fine on the back! Ad for speedo accuracy once i get the head rebuilt an running again i'll GPS speed check her on my phone! "you'll probably have them on your car by then but"
