I got a selector bar modified to work for a 5 speed so have had to put that on, put new linkages and in too. I need to get the right spot on the spline, I almost got it right then it moved to far and I was way back out!
Just so I am getting this right, I need to get a 20mm gap on the bottom of the shift to space it out, then get the selector point straight up on the splines?
All systems are go!
Finally got the linkages sorted, changed out all the bushings which made all the different.
Just took it for a spin, muffle is hitting so waiting for it to cool and will adjust it and take it out for a long run to iron out any bugs.
Big thanks to Jaimo who gave me a hand with it last night, he is a member here of the same name, only comes on occasionally though.
Everything should be sweet for the trip to melbourne.
excellent work, can't wait to see it in person!
Took it for a long service run late this arvo, couple of issues to sort out but it seems to be running ok. It's got an exhaust leak around the extractors and maybe an inlet leak also, I think i need to chase up an inlet and exhaust gasket for it, I have a feeling they are the culprit.
Engine goes heaps better than the 1600, I think i'm going to need to chase up a weber for it though, the stock carbie must be holding it back.
Nice work man.
That water inlet looks familiar. That is from a certain blue car yes???
I have gaskets if you get stuck.
Yep, the engine is from the blue mk1.
Off to go change the strut top mounts now, the passenger side has ripped itself out badly, good it did it now and not going down the Hume![]()
