Page 4 of 8 FirstFirst ... 23456 ... LastLast
Results 31 to 40 of 72
Thread: New Addition
  1. #31
    Jun 2007
    Eastern Suburbs Melbourne
    sounds plausable. could also be an iffy headlight switch as well. depends how badly the push start has been wired i reckon
    i like volkswagens
  2. #32
    Jun 2008
    Hobart, TAS
    Yep had the same problem, ended up being two different things, ignition switch was buggered and replaced with a push-button
    and also the headlight switch was wired incorrectly so lights would stay on regards of switch pos.
    check all the light wiring, chances are you may have something connected to constant power, but the coming on and off intermitently is different.
    good luck with it, would look the ducks with some coilovers and wider rims
    1979 Mk1 Golf GTi
    1994 Mk3 Golf VR6
  3. #33
    Jun 2006
    Orange NSW
    Quote Originally Posted by static1800 View Post
    Not quite following you Preeny, is that to reattach the window the hinges or to seal the 1/4 shut?
    Ahh sorry dude. To reattach the hinges to the glass. Fix 'er up back to original.
  4. #34
    Jun 2006
    Orange NSW
    Nice find! its getting harder and harder to find rust free mk1's.
    If you dont want to be able to even open your 1/4 windows you can just sikaflex around the rubber seal its great stuff but dont get it on your fingers!
    Mk2 GTI 2 door 1.9l 8v turbo 1st mk2 1st engineered water vw nats 09
    Mk1 twin eng twin turb
    scirocco gti 2.1l 16v turb 6spd
    Audi A4 B5 1.8t
  5. #35
    Oct 2005
    Nowra, NSW
    Not fussed whether to open them or not, the main issue at the moment is both of the latches are missing, both the windows seem attached to the hinges though. If I can get the latches I will put them back to original.
    Fixed the dodgy ignition switch, all seems good now hopefully no more flat batteries
  6. #36
    Oct 2005
    Nowra, NSW
    So i've been out doing some work on it finally, I want to drive it down to DOVW so some tidy up is in order.
    Swapped out the taped up opening 1/4 vents for sealed ones lastnight, much better and much more secure!
    Decided to pull up the carpets and take a look.
    Wet Carpet: Check!
    Wet undermatting: Check!
    Wet noise sealer stuff: Check!
    Rusty Floors?..... nah not really
    There was more mud and dirt under everything than rust.
    Gave it a quick hit with this and some 80grit and its all clean still got to clean out some of the mud and rubbish...
    Trying to work out how i want to treat it, can you buy POR15 in a small tin? i've got some rust converter I will put on for starters so it's all good and clean.
    Is that padding just to keep noise out? that stuff holds so much damn water! the passenger side was dripping and this car gets garaged!
    Any alternative to it that are better? Dynamat?
    Got some more work lined up for it, you will have to wait and see, should be looking good for DOVW
  7. #37
    Jan 2009
    south west sydney
    looks good! did you have the fixed 1/4 vent already or did you purchase it for the job. mine are currently stuck in with silicone sealant
  8. #38
    nice mate, I've been through the redoing of the floors
    I just painted mine with Stonguard which works well Also you dont really need that sound deadening stuff
  9. #39
    Jun 2007
    No, dont listen to Josh he's silly. you do need sound deadening, esp if you want to enjoy dailying this!
    didn't mike or ayden use aq few layers of regular carpet underlining?
    i like volkswagens
  10. #40
    Oct 2005
    Nowra, NSW
    Is the sound deadening the thick stuff? or the rubbery stuff that is stuck the the floor? or both?
