Yep had the same problem, ended up being two different things, ignition switch was buggered and replaced with a push-button
and also the headlight switch was wired incorrectly so lights would stay on regards of switch pos.
check all the light wiring, chances are you may have something connected to constant power, but the coming on and off intermitently is different.
good luck with it, would look the ducks with some coilovers and wider rims
1979 Mk1 Golf GTi
1994 Mk3 Golf VR6
