Single for the win...![]()
single looks a hell of alot better IMO![]()
single looks lots better, i've seen it in real life. makes the car wider.
Will looks even more better er with your rims on.
ONLY 8 THINGS!!!!
dean's a good bloke to me!
Adjust linkages - easy as!
Rust in D.S. headlight - replace
Rust in D.S. rear tail light - replace
Front seats do not tilt - need to find some
Adjust D.S. rear wheel bearing - easy as!
Clean around outer front CV boots - so i don't have to replace them
Fit fuel pump relay - so its not on when the ignition is on, only when it receives a signal from the coil- got one ordered in and will install it 2moz
Replace speedo cable - noisey
so thats fairly easy i'm quite happy!
should get it all done 2moz.
yea man. not a bar list.
seen worse.... [looks at josh...]
your inbox is full, but i'll help you out tomorrow.
yeh nice one bro, my RWC list was like reading War and Peace!
ill help when i can![]()
Good work Stu.
I've had this discussion with heap's of dubber's incl. some of you on here about singles & twins.
I go the singles everytime. Give's the car a wider & fatter stance without fail!
