Page 34 of 56 FirstFirst ... 24323334353644 ... LastLast
Results 331 to 340 of 558
Thread: NEW 2 Door golf! :D:D:D:D:D
  1. #331
    Jul 2005
    Newcastle, NSW
    I gave up and will let a mechanic do it.
  2. #332
    Boronia VIC
    Quote Originally Posted by thestu View Post
    any ideas on getting that 30mm nut undone?
    Brute force and ignorance.
  3. #333
    Boronia VIC
    30mm socket....
    and rotate it anti-clockwise..............
  4. #334
    Aug 2006
    Melbourne VIC
    Get a strong metal bar and give some leverage to the breaker bar!
  5. #335
    I've seen socket's shatter trying to undo seized on driveshaft nut's.
    I've also got a top of the line snap on rattle (cannon) gun & that can't even budge them!
    If it's really siezed on good, I soak the crap out of it with wurth rost off & in some cases overnight!
    I use a long snap on breaker bar & preferrably a impact socket & a big steel pipe I've got here.
    Also have someone in the car with they're foot firmly stamped on the brakes.
    Sometime's giving it a hit with the old knockometer can shock it too.
  6. #336
    Boronia VIC
    Golf drive shaft nuts are a service item, they're not supposed to re-used. Provided you can source new ones (GAP sells them) you can always drill and split the real stubborn ones.
    Pete
  7. #337
    Aug 2006
    Melbourne VIC
    Hey i was just thinking isnt it a 27mm deep socket?
  8. #338
    Pete
    This is true, as they a crush/self locking nut
    But if they if your alway's pulling them out on your own car, you can reuse them a couple times.
    If it's a customer's car, then replace them without question. They also come new in CV Joint boot kit's.
    One other thing I highly recommend & do without question myself.
    If you have to replace one wheel bearing, you should definately replace them as a pair & replace the other one.
  9. #339
    Eastern suburbs of Melb
    thanks boyssss! i had a 30mm socket with a breaker bar and a long pole on her and had it in gear and the motor just turned over lol so i will have to get someone to stomp on the brakes.
    i will tell ya how it goes
  10. #340
    Nov 2005
    newcastle
    no handbrake?
    you can also use wheel chocks or bricks
    TDI mk1 on the road!!
