i will get the code within an hour for you
i just cbf waking up right now
From memory it's a 4K
Right on the mk1/2 change over with 90mm CV Joint's, the close ratio's & short final drive.
Cool, that's about the hardest accelerating stock 5 speed there is.
With that box and the K-Jet 1800 you'll be faster off the line line than Josh and Jarrad.
You should be faster than me too! (Well, quicker than one of my Mk1s)
Your ratios are
3.45 2.12 1.44 1.13 0.89 with a final drive ratio of 3.94
This is the close ratio gear set and the lowest diff ratio easily available.
It's not going to be the most economical though
Assuming 185/65/14 tyres you'll be at 3120 rpm @ 100km hr.
Should be lots of fun at the traffic lights!
Good luck with the RWC, I'll see you some time over the weekend for those scrapers.
Pete
I hate to say it but, from my experience's there also the weakest box of gear's I've encountered.
It's a funny thing, but my diesel 4 spd was actually faster in a sprint & could be pushed beyond the top speed of my close ratio 5 spd's too!
But having that 2.12 2nd is pretty nice & you definately notice it, cause that's the main difference.
more problems with the golf today...had it running adn the engine just stopped...the pump it now stuffed
the tank sender is also stuffed...the lil plastic sensor for the fuel gauge has come out and i can't think of how to put it back in. so its leaking...
exhaust not in yet
no door latches
nothing going for me
