Page 22 of 56 FirstFirst ... 12202122232432 ... LastLast
Results 211 to 220 of 558
Thread: NEW 2 Door golf! :D:D:D:D:D
  1. #211
    Boronia VIC
    It's basically the 4+E from memory isn't it stu?
    Its the 5 speed I'd go for, in a streeter. I think the ratios are too quick in the 5 speeds. just imo though.
    There's a lot more than just 2 types of 020 gearbox.
    Pete
  2. #212
    Eastern suburbs of Melb
    i will get the code within an hour for you
    i just cbf waking up right now
  3. #213
    From memory it's a 4K
    Right on the mk1/2 change over with 90mm CV Joint's, the close ratio's & short final drive.
  4. #214
    Quote Originally Posted by golfworx View Post
    thats the one! legend! thanks tim i knew you would come to the rescue
  5. #215
    Boronia VIC
    Cool, that's about the hardest accelerating stock 5 speed there is.
    With that box and the K-Jet 1800 you'll be faster off the line line than Josh and Jarrad.
    You should be faster than me too! (Well, quicker than one of my Mk1s)
    Your ratios are
    3.45 2.12 1.44 1.13 0.89 with a final drive ratio of 3.94
    This is the close ratio gear set and the lowest diff ratio easily available.
    It's not going to be the most economical though
    Assuming 185/65/14 tyres you'll be at 3120 rpm @ 100km hr.
    Should be lots of fun at the traffic lights!
    Good luck with the RWC, I'll see you some time over the weekend for those scrapers.
    Pete
  6. #216
    Your ratios are
    Pete
    WOOO HOOO! thats just plain awesome! i can't wait to drive her
    thanks for that good info pete! yes i shall see you over the weekend
    hope your knee is getting better
  7. #217
    I hate to say it but, from my experience's there also the weakest box of gear's I've encountered.
    It's a funny thing, but my diesel 4 spd was actually faster in a sprint & could be pushed beyond the top speed of my close ratio 5 spd's too!
    But having that 2.12 2nd is pretty nice & you definately notice it, cause that's the main difference.
  8. #218
    But having that 2.12 2nd is pretty nice & you definitely notice it, cause that's the main difference.
    ok...well i think 2nd is rooted so i don't think i will be pushing it hard...i shall get it roadworthy and if it is stuffed im gunna pull it out chuck my diesel 4spd in and then get an lsd and get the 5 spd all done up nicely
  9. #219
    Boronia VIC
    I've got one of those Diesel 4 speeds in one of my cars behind a 1.8 ADZ motor. Seriously fast!
    Code GC
    3.45 1.94 1.28 0.91 with a FDR of 3.89
    3150 rpm @100kph though
    Stu, LSD's aren't cheap! you might want to consider an 80% pelolock kit first.
    Pete
  10. #220
    more problems with the golf today...had it running adn the engine just stopped...the pump it now stuffed
    the tank sender is also stuffed...the lil plastic sensor for the fuel gauge has come out and i can't think of how to put it back in. so its leaking...
    exhaust not in yet
    no door latches
    nothing going for me
