Originally Posted by
Peter Jones
Yep throttle Body was what I was rambling on about. The later MK2 and Audi one have a 52mm primary and a 35 mm secondary butterfly (from memory) which is the biggest bolt up type available. Some of the GTI motors had the smaller kind.
I have a spare Audi one here that I bought by mistake think I had the smaller type. I think I only paid $20 for it, yours at that price if it suits.
I think volvodriver is referring to your rusty gearbox mount.
You should be able to hook up that late model reverse switch in the box, the 1600 micro switch ones suck. They're easy to wire up and work fine, from memory they're 2 pin devices - just plug in the original wiring. If it's got more than 2 pins just google up the wiring, it's just a matter of knowing which 2 pins to use.
I can check mine for you, I've got all types, but I'm laid up in bed for a week recovering from knee surgery, so it won't be 'till the weekend at the earliest.
Look forward to seeing it on the road.
I have a co meter and know how to set the mixture on a KJet now, you'll have to bring it around for a tune when it's done.
Pete
