Page 23 of 56 FirstFirst ... 13212223242533 ... LastLast
Results 221 to 230 of 558
Thread: NEW 2 Door golf! :D:D:D:D:D
  1. #221
    Boronia VIC
    Those pumps can be an issue. You need to check your wiring, you may have blown a fuse.
    Firstly check the fuel pump relay (you did fit one didn't you?) These can be the cause of a lot of grief.
    As these pumps age the internal bearings wear out and they can jam up internally. When this happens they stop turning, draw heaps of current and blow the fuse ( or melt the wiring if you don't have a fuse).
    To get them going again on the side of the road a couple of light taps with a hammer usually frees them up again and they'll get you home, but that's about it.
    A pump in good condition will draw about 5 - 8 amps and it it will pull over 20amps when it stalls so your wiring should be setup for those sorts of currents. I went through a heap of 20Amp fuses until I worked out what was going on with my pump.
    So, make sure your wiring's up to it, check there's power at the pump and give it a thump.
    If thumping it makes it go, you're up for a new pump I'm afraid.
    Pete
  2. #222
    Boronia VIC
    Oh and don't forget this site about K-Jet
    http://www.auto-solve.com/mech_inj.htm
    I keep a print out of it in my Garage!
    Pete
  3. #223
    Eastern suburbs of Melb
    Pete
    yes i definitely had a relay and a fuse
    the car was runnign and just stalled..so i bypassed the relay to try the pump...the wire just sparks and the pump sounds like its seazed i shall try the tap trick! i should really get one of the proper k-jet pumps and run an accumulator and a pressure reg..but atm the just have the pump going straight into the fuel filter then into the k-jet...but i never had any problems with it running...and worked well at high rpm.
    with the tank sender should i jsut try and get a new one? or a good second handy? ir try and fix the one i have? what is a glue that will not perrish when fuel touches it?
    Stu
  4. #224
    Camden, Sydney
    Try swopping the wires over on the pump and running it backwards for a minute. That can unjam them too
    Remember kjet is picky with foreign matter and slurry from the bottom of the tank. A full tank of fresh fuel and a good filter would help matters.
  5. #225
    will try that too
    i just swapped the tank over and put good clean fuel in and a new fuel filter!
    should i run na filter before the pump?
    i was told not to because it may not work properly
  6. #226
    Boronia VIC
    Nope to the pre filter, It's all going through the main filter all the time any way. You should be running an accumulator though.
  7. #227
    ok
    where do i find an accumulator? how do i get one?
    Stu
  8. #228
    Boronia VIC
    You could try fishing around under a volvo for one, ideally you'd get a Golf one though. Try asking in the wanted section.
    Pete
  9. #229
    Pete
    kk thanks pete
    i sent you a message on your phone before did you get it?
  10. #230
    Boronia VIC
    Quote Originally Posted by thestu View Post
    kk thanks pete
    Wasn't watching! - Replied
    Pete
