Page 11 of 56 FirstFirst ... 91011121321 ... LastLast
Results 101 to 110 of 558
Thread: NEW 2 Door golf! :D:D:D:D:D
  1. #101
    Jun 2006
    Orange NSW
    hey man - if you want to save a buck on getting in the windscreen, its easy to do yourself. all you need is a bit of nylon chord....
    And a riggers glove, and someone to give you a hand. One of you will need to not have carpal tunnel, so that you can slap the windscreen in as you go around.
  2. #102
    Eastern suburbs of Melb
    sweet yeh thanks boys i have done a few windscreens on bugs i'm guessing they are pretty much the same yeh? we used rp7 in the channel and electrical wire 2 guys and some slapping
  3. #103
    Gosford Central Coast NSW
    i did it by myself.... you guys are SOFT
    i did use some red rubber grease
    '98 Mk3 Cabriolet 2.0 8V
    '99 A4 Quattro 1.8T
  4. #104
    pffffft doing it yourself doesn't make you hard..
    getting help is just easier man...and faster...beetle windscreens are my forte easy as pie
    let me re phrase that...beetle windows
  5. #105
    Jun 2007
    Eastern Suburbs Melbourne
    After seeing the windscreen guy do mine, it realy is easy as pie, about as easy as it is to do the rear 3/4 windows on a 2 door
    i like volkswagens
  6. #106
    did you do your 3/4 windows?
  7. #107
    Jun 2007
    yep. easy as pie. used a bit of string (needed something thicked thou) a bit of WD40 and hey presto.
    I saw somethig on clubgti ages ago that had a write up on how to do them in a mk 2, but it's the same for a mk 1
    i like volkswagens
  8. #108
    Aug 2006
    Melbourne VIC
    Bit of rope is ya friend
  9. #109
    Jun 2006
    Orange NSW
    Thick venetian blind cord is the go.
  10. #110
    I was hard at work on my golf thius arvo and got the engine bay in primmer...it still needs work but its a guid coat so i can see the stuff ups underneath and fix them
    here you go:
    also built this k-jet box at school but i made it too long and it won't fit so i will hack the end off on tuesday next week and weld it up a lil shorter
