if the injection pump isn't leaking, it'll probably out last the car.
Glds tend to occasionally do headgaskets, which often can crack the head & can be hard/expensive to repair.
The injection pumps aren't cheap items to get reconditioned/replace with new. a 2nd handy shouldn't be too expensive, if you can find out.
They also tend to wear out rings as well. this will be evident by blue smoke out the exhaust.
i've had mine for about a year now, and the only thing I've done is replace the glowplug relay. I've had no other issue with it.
And yes, they're slow. not catastrophically, but you'll notice it![]()
