Big question with 1000's of answers depending on your resources!
Not able to give full opinion now but I suggest you use something like the ADZ but keep it carb, that will give a really handy 120hp whihc gets along, and still be ok for club plates![]()
Hi all,
I've recently purchased my first Mk1 after owning a Mk4 for 2 years now as well. Its a 1979 GLS. I'm 18 and have minimal car knowledge but i'm pretty good with my hands if I've got some guidance. My Mk1 currently doesn't run and the engine was robbed for parts at some point in its life and sadly its ceased. I'm looking to do an engine swap of some kind but i'm not sure what with. I've heard a lot of newer engines (mk3/mk4) engines are straight bolt ins but i'm having trouble understanding how the ecu side of things work in an older car with no computer. Do i need to get the ecu for the motor with it and also a loom or can i keep the current loom and use that (this may be a very dumb question :/) I'd like to keep the 4 speed box i've got if possible and just get a new engine. All i'm really asking is whats a decent power engine that's easily sourced in Victoria and will be the easiest to install! I've got a lot of friends who are good with cars and we will have no problems doing all the work ourselves (as i learn along the way, basically what the car was purchased for). Thanks for the help
And what car will i find the ADZ engine in?![]()
Never mind i've just realized its a 1.8 from a Mk3! So what about wiring and stuff?
Best to do is get the ADZ motor from a Seat cordoba. I've done this engine swap about 5 times now haha. You will need an electric fuel pump to supply fuel. Everything else from the 1.6 should bolt in too, including engine mount, exhaust, intake and carb, etc.
While you have the motor out, its best you change all seals and bits, ie; front main, rear main, rocker cover and sump gaskets, spark plugs, timing belt, water pump etc. This will ensure it performs reliably and its easier to do this maintenance while the motor is out.
Carby will need to be re tuned and jetted for the larger engine. Best option is to find a larger 32/36 weber with Passat TS manifold. Goodluck!
- Brown U.S import 81 cabby
- 88 Honda crx b18cr
I'm fairly certain the engine is a 1.5 not a 1.6, will it still be the same deal?
In addition to what George said. The ADZ can accommodate a mechanical fuel pump so is literally a straight swap for the motor. You simply need to block the block breather with a plate and mount the fuel pump through the plate onto the intermediate shaft eccentric lobe (I can provide pics in the next few months or so).
ADZ is a great engine and so many are around. I prefer the 1.8 over the 2.0l. I have never been overly impressed by a 2.0l 8v mk1, even on IDF carbs with a cam. 1.8 feels much nicer and will rev harder.
1978 MK1 2.0 16v http://www.vwwatercooled.com.au/foru...-46488-70.html
1991 MK2 GTI 2.0 8v, white (RIP) and it's red replacement http://www.vwwatercooled.com.au/foru...gti-42078.html
1997 MK3 CL http://www.vwwatercooled.com.au/foru...ml#post1292061
2001 & 2002 Bora 4motion. http://www.vwwatercooled.com.au/foru...st-123823.html
I've got access to a ABA 2L from an mk3, is this swap easy?
ABA wasn't brought to Australia... How you get that?
