Results 1 to 10 of 15
Thread: Need help with my 79 Mk1 GLS!
    Aug 2016
    Sunbury, Melbourne
    Hi all,
    I've recently purchased my first Mk1 after owning a Mk4 for 2 years now as well. Its a 1979 GLS. I'm 18 and have minimal car knowledge but i'm pretty good with my hands if I've got some guidance. My Mk1 currently doesn't run and the engine was robbed for parts at some point in its life and sadly its ceased . I'm looking to do an engine swap of some kind but i'm not sure what with. I've heard a lot of newer engines (mk3/mk4) engines are straight bolt ins but i'm having trouble understanding how the ecu side of things work in an older car with no computer. Do i need to get the ecu for the motor with it and also a loom or can i keep the current loom and use that (this may be a very dumb question :/) I'd like to keep the 4 speed box i've got if possible and just get a new engine. All i'm really asking is whats a decent power engine that's easily sourced in Victoria and will be the easiest to install! I've got a lot of friends who are good with cars and we will have no problems doing all the work ourselves (as i learn along the way, basically what the car was purchased for). Thanks for the help
    Nov 2014
    Big question with 1000's of answers depending on your resources!
    Not able to give full opinion now but I suggest you use something like the ADZ but keep it carb, that will give a really handy 120hp whihc gets along, and still be ok for club plates
    Aug 2016
    Sunbury, Melbourne
    And what car will i find the ADZ engine in?
    Aug 2016
    Sunbury, Melbourne
    Never mind i've just realized its a 1.8 from a Mk3! So what about wiring and stuff?
    Jan 2010
    Melb Westsideeeee
    Best to do is get the ADZ motor from a Seat cordoba. I've done this engine swap about 5 times now haha. You will need an electric fuel pump to supply fuel. Everything else from the 1.6 should bolt in too, including engine mount, exhaust, intake and carb, etc.
    While you have the motor out, its best you change all seals and bits, ie; front main, rear main, rocker cover and sump gaskets, spark plugs, timing belt, water pump etc. This will ensure it performs reliably and its easier to do this maintenance while the motor is out.
    Carby will need to be re tuned and jetted for the larger engine. Best option is to find a larger 32/36 weber with Passat TS manifold. Goodluck!
    - Brown U.S import 81 cabby
    - 88 Honda crx b18cr
    Aug 2016
    Sunbury, Melbourne
    I'm fairly certain the engine is a 1.5 not a 1.6, will it still be the same deal?
    Feb 2013
    Melbourne SE
    In addition to what George said. The ADZ can accommodate a mechanical fuel pump so is literally a straight swap for the motor. You simply need to block the block breather with a plate and mount the fuel pump through the plate onto the intermediate shaft eccentric lobe (I can provide pics in the next few months or so).
    ADZ is a great engine and so many are around. I prefer the 1.8 over the 2.0l. I have never been overly impressed by a 2.0l 8v mk1, even on IDF carbs with a cam. 1.8 feels much nicer and will rev harder.
    Go 2.0 16v with twin Dellortos.
    170 hp, heaps of money, lots of things to convert, wiring headaches like you wouldn't believe but looks awesome.
    Need help with my 79 Mk1 GLS!-yellow-engine-bay-4-jpg
    Aug 2016
    Sunbury, Melbourne
    I've got access to a ABA 2L from an mk3, is this swap easy?
    Feb 2013
    Melbourne SE
    ABA wasn't brought to Australia... How you get that?
