Results 1 to 3 of 3
Thread: need advice on upgrading to a bigger clutch
    Nov 2005
    newcastle
    hey guys,
    Ive got a long ratio 5 speed on my 1.8 and im looking at replacing the clutch. Im pretty sure it has the normal 190 mm clutch in it out of a 1.6, but i was wondering if its worth upsizing to the gti clutch to handle the extra power,
    im also curious if any extra parts are needed for the upgrade as i aparently need a bigger flywheel to match
    thanks
    TDI mk1 on the road!!
    Golfwise Guest
    I have a correct 210 mm flywheel if you need it.
    Sunny Coast - The QLD
    Go for the biggest one you can stretch the budget to. Its worth it when you up the power.
    MK1 floG soon to have 16v 2L with cable change gbox - need a 16v turbo manifold
    "Fit the gearbox ya bum." Loon - best post ever!
Similar Threads
  1. HELP! Clutch pedal stuck all the way in...
    By gman in forum Mk3 Golf & Vento
    Last Post: 24-01-2007, 07:33 AM
  2. Clutch Master Cylinder
    By Snoopycrx in forum Polo (9N & 9N3, 2002 - 2009)
    Last Post: 07-12-2006, 03:37 PM
  3. CLutch Pedal - Hydro
    By golf3 in forum Mk3 Golf & Vento
    Last Post: 30-06-2006, 07:47 AM
  4. CLUTCH!!!!!! help... 2E series 8v motor
    By 86gti in forum Mk2 Golf & Jetta
    Last Post: 17-04-2006, 06:52 PM
  5. Which clutch
    By Gas in forum Mk1 Golf
    Last Post: 03-08-2005, 05:50 PM
