I reckon when you're going round the corners the float bowl of the carb is emptying. I had a similar problem (though I never solved it) I believe the fix is to adjust the float level a bit higher. That is, instead of the car 'skipping' it's actually cutting out moementarily when you're going around a bend. it's almost as if you're on and off the throttle like a switch, which makes the car jump around a bit. perhaps it's even similar to a learner on 'kangaroo juice'!
I'm hoping Pete Jones can elaborate on this a bit.
