Nah dude, im sticking with black. Just gotta get some smaller profile tyres and stretch em'.
Well guys heres my problem. Iv got that long bendy rod and have extended the bit underneath with the c clamp. I extended it to REVNIT's measurements. Now
the problem i have is the ratio is waaaay too close. I have driven it although the gears seam really wierd and its very hard to get 1st and 2nd. Im thinking if i
make that c clamp bit underneath that joins the long rod, a bit shorter hopefully ill have a bit further ratio. I still need to work on getting 5th into the picture haha.
Not only that but where first is ment to be, reverse happens to be there? any ideas at all?
Apart from that seems like we have got the timing pretty good as the car starts pretty quick whether it be cold or hot which is good, although im not sure if its due
to the cold but it smokes from time to time, today was white-ish smoke, but im pretty sure iv seen black, although it might be a mistake? It idles at 1000 rpm
steady and doesnt drop. Only today for some reason while i went around the block, when i stopped the car jsut couldnt idle alone and stalled. this happened 3
then worked fine again? By the sounds of my explenation is there anything wrong? One more thing is would someone recomend me where the best place to tune
the golf would be as it needs one.. thanks guys
George
