After inspecting it for some time i thought id start on the wires. I took the alarm out as i got told it wasnt working properly and thought id try get everything else working as no indicators, horn , lights, or windscreen wipers were working.
when i took off the carpet i found out a bit of rust around where the seats go. i got to work on fixing that up aswell.
it was alot of wires everywhere and i had to re-do alot of it. everything was messed up and alot of the cables have been changed to differnt colours and i had to chase up every wire and label it.
I happen to go past a wreckers yard on Mcantyre road and happen to find a 2door mk1 sitting there. i ended up buyign that golf for $600 without wheels. the interior is quite worn and the body is starting to fade. it would be a great project for later on.
I took out the wiring loom from that golf and just through it in Mine. It made life alot easier as everything was to factory spec and the wires were all continous and didnt change half way through.
