Page 41 of 66 FirstFirst ... 31394041424351 ... LastLast
Results 401 to 410 of 656
Thread: My sort-of restoration
  1. #401
    Jan 2010
    Melb Westsideeeee
    That urethane can be applied with a solvent resistant foam roller I believe. Might be worth going and asking someone at the counter.
    I wouldn't use contact either. Try a sign writing supply place like Supply one and get some clear sign writing vinyl. It comes in sizes big enough to cover a truck and is weather proof for 8 years.
    Welcome to Supply One - Home
    You make me move towards the sign writing place. Since they do specialize in stickers and such.. thanks mate would never have thought of it. I just went past and saw clear vinyl contact liek the ones for books, a whole 1.5m roll for about 5 bucks. I want to try it but am scared if it fades or shrinks due to heat, when i try to take it off it will take have the stickers off too .. so i'll jsut do more research.
    On another note, i just got a stock exhaust from a friend, from his Civic Ek. It has the same dimensions, and hopefully ill be able to put it on soon, because my current exhaust is too loud an driving me crazy.
    My carb will also be going up for sale soon because they way i drive it drains my petrol, and its a performance carb. Only thing that pisses me off is, as i take corners, there seems to be a sudden loss of fuel and the car cuts out. Its very strange.. any thoughts? (this has been going on for a long time)
    - Brown U.S import 81 cabby
    - 88 Honda crx b18cr
  2. #402
    Boronia VIC
    Quote Originally Posted by GeorgeMK1 View Post
    That's typical of a progressive weber on a passat manifold, you need smaller jets and the float level set up properly. Do a bit of google'ing on the subject, it shouldn't be too hard or expensive to sort it out.
    7? MK1 Caddy
    79 B1 Passat Dasher Project
    12 Amarok
  3. #403
    Jun 2007
    Eastern Suburbs Melbourne
    What pete said! Just need to get the carb sorted properly, that's all.
    i like volkswagens
  4. #404
    Sep 2009
    Chillaxing in Tas
    pretty sure he has a carb off a falcon, if the jets havnt been touch it will use bucket loads of fuel.
    Go a 32/36 weber, i have a list of jets and what not to use a base start for a 1.8L
    <space for rent>
  5. #405
    What sort of economy should you be getting with a32/36 weber on a 1800?
  6. #406
    Jan 2010
    Melb Westsideeeee
    The other day i put in 14L of fuel, and got around 120 kms.. but thats me driving VERY slow and changing early.
    The carb has already been jetted down, but still is ment to be for a 4.1 Falcon XF
    Ill have to ring the guy up as it was rebuilt less than a month ago. Hopefully he can jet it further down..
    On my way home today, not even turning, just going dead STRAIGHT the car started jerking back and forth, like a fuel shortage, then after 5-10 seconds went back to normal. This happened 3 times. Im getting quite annoyed
  7. #407
    Sep 2009
    Chillaxing in Tas
    Same, if not better then a stock solex carby.
    My old engine and weber got around 9L/100kays under heavy driving, no HWY either.
    <space for rent>
  8. #408
    Jun 2007
    my old 1.6 did around 12's, But it was never set up properly, and ran rich. (over jetted)
    George, when was the last time you replaced the fuel filter? You could be getting some crap/debri in the fuel line/ fuel flow, which is causing the jerky ness.
    i like volkswagens
  9. #409
    Jun 2006
    Orange NSW
    I'd be checking all your jets for crap in them dude.
  10. #410
    Sep 2009
    Chillaxing in Tas
    ive heard that you can rev the car up to around 3k and slam your hand over the carby with the filter off and the sudden vacuum rush in it can suck all the crap out of it.
    Ive seen a mechanic friend do it once or twice, its usually a 50/50 fix, as sometimes it can lodge crap further in the circuits
    Also, 80% of your driving will be done on the Idle circuit, so getting that setup spot on is crucial
    <space for rent>
