Results 1 to 3 of 3
Thread: fuel pump mk1 gti
    Sep 2007
    perth western australia
    fuel pump mk1 gti
    Has anybody here had a situation when the fuel pump stays on while the ignition is on but the engine not running ? in the past on my mk2 gti and mk1 16v the pump would only come on for a few seconds . any ideas ?
    Nov 2009
    Sounds like you have the wrong relay, the early fp relays have an external 16amp fuse. Depending on whether the car has had the 'relay recall' done the relay will either be mounted on top of her fusebox (second position from left, I think) or on the fusebox itself, again second position in from the left. Both early and late relays will have 5 prongs.
    HTH Gav
    Sep 2007
    Quote Originally Posted by Vinda76 View Post
    HTH Gav
    Ok gav will investigate this afternoon and check on the relays and see how they match up....
