I quick list of the work I had to do to get it passed for transfer of rego ownership...
Replaced headlight bulb.
Replaced fan belt.
Cleaned out the window washer jets.
Re-joined the window washer jet hose on both ends...
Replace window wiper heads.
Cleaned the paint off the front indicators.
Repaired the knob on the drivers window winder.
Moved the boot light into the cabin so that there is a door light.
Put a lower seat cover to 'repair' the small hole in the drivers seat.
Put a floor mat down to 'repair' the small hole in the drivers foot well carpet.
Cleaned out the reverse light switch and it now works again.
The flange seals have fixed themselves... Yippee...
What appeared initially to be an engine oil leak, looks like it was mostly spillage and an ever so slightly leaking sump plug, which I tightened.
Lubed and adjusted the clutch cable, so that's a little better to use.
Car had it's check, and as expected, it failed...
Both front seats failed due to excessive movement...
Both boots failed (expected, and ordered, but they didn't arrive till the day of the inspection)...
Clutch firewall repair plate was cracked...
So, I then spent all night fabricating a new repair plate, and fitting both steering boot and cv boot...
The next morning, I checked the seats. The seat runner plastics have had a 1mm thick, strip of plastic (piece of an old credit card) used as a spacer between the metal foot of the chair, and the inside of the plastic feet that run inside the runners. The seats now have no movement in the base, and they slide back and forth very nicely...
It then passed rego...
