then ill take the steelies of ur hands when that happens wabit![]()
yeahh i wont be able to fit my 14's on soon because i am going to have big brakes soon, audi quattro 4piston calipers with cross drilled 280mm rotors, they just fit the vr6 witht the stock bbs 15's
wabit
has anyone investigated the old volvo 4 potters to see if they can be adapted to fit? You can pick them up for around $50 -$100 a pair and they mught just do the trick. Pads would be cheap too.
A friend of mine is using them on his beetle and they work unbeleiveably well. The only problem is they're very heavy, a lot of unsprung weight. I have been thinking of looking into them as well.[/quote]has anyone investigated the old volvo 4 potters to see if they can be adapted to fit? You can pick them up for around $50 -$100 a pair and they mught just do the trick. Pads would be cheap too.
I have heard that volvo 4 pots fit the mk1 hubs, but you need to drill through the fluid gallery and block off 1 hole, as they have brake lines coming in from each side of the caliper. But dont quote me on that
-Jamie
76' Mk1 Rally Car, 1800 8v haltech ecu
94' Fairmont Ghia, v8, big cam, leather, perfect for towing golfs
89' EA ex taxi, lpg, cheap and easy
